Electrical prob?
lambgsr1
I got a 94 Integra GSR and I recently swapped out my Distributor and now it runs like shit. What do you guys think's going on. Is it electical or something else? The car hesitates like mad, kinda like the A/C is on.
if you got the distributor from a junkyard id check to see if the bearing is seized on the distributor shaft. the distributor rotor would be hard to turn at that point. id also see if there is a moisture or water inside the distributor cap. otherwise then that id look at the ignition coil swap it out from your old distributor if i worked.
