Engine code?
Discussion in 'General Tech and Maintenance' started by jeff roys, Nov 12, 2006.
  1. jeff roys
    jeff roys New Member
    I'm a new honda owner and want to know if anyone knows where to find the engine code, b16 etc. I bought a 94 del sol and it does not have any badges or marking on the outside. The top of the engine says v-tec, any ideas, thanks.
  2. jeff roys
    Del sol
    Thanks, if that is the case, do you happen to know the specs on that engine? I was hoping to have the 160hp version.
  3. Estorvito
    Estorvito Soy Boricua
    Orlando FL
  4. jeff roys
    Its a si, I was hoping I had the 160hp doch vtec. It is a v-tec soch but it only has 125hp. I bought it with mods but I have no idea where it is at currently.
  5. jeff roys
    mods
    It has an AEM air intake, carbon fiber muffler, aftermarket race headers, and I am told it has a chip(mugen). Not sure where the ecu is so I am not sure how to check. I am told I can put my car on a dyno nearby fo 20 bucks so I may do that sometime. For now I am just gonna work on the inside with some white face gauges and stuff like that.
  6. jamesA
    The ECU should be under the carpet on the passenger side in front of the door.
  7. kkid28
    kkid28 He who burns the rubber.
    Regina, Saskatchewan.... Canada!
    Might accidentally think you're going 6mph at 120000 rpm or something? lol How would you screw them up?
  8. jeff roys
    I have wondered why I was not getting the fuel economy I thought I should out of a four banger! I have been doing some research on the gauges, would you guys still not recomend them if they were installed by someone who knows what they are doing? How about a race style steering wheel, are those hard to do?
    Thanks for all yous guys input!
  9. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Check my sig for installing a "race style" steering wheel.
  10. jeff roys
    Thats awsome, thanks!! Do you have anything on white face gauges?(the cool multi color ones)
  11. Andrew
    Tallahassee, FL
    Sry I don't. I've never messed with them, and probably won't ever do 'em... it's just not my style.
    Just be carefull and follow the instructions carefully.
    I'm sure you can find info online somewhere.
  12. jeff roys
    Gauges
    I believe you, but it just seems so screwed up. I have heard so much about this and WILL heed the warnings. I just don't understand why you can't replace the needle at 0 and be ok. I have been calling around and will end paying someone to do them. Any way to tell if they have been jacked up or do I just cross my fingers?
  13. Andrew
    Tallahassee, FL
    Is it that important to you?
    I'm not saying, "don't do it", but, if theres risk of messing up your cluster, why bother with it?
  14. jeff roys
    Just beacuse I already bought them from ebay.
  15. jeff roys
    I guess you are right in the long run though.
  16. jeff roys
    I guess that is always an option! Now I guess I will just redirect my efforts somewhere else.
