Engine Harness
delslow
Member
Alright here is the problem, I been trying to figure out if anyone makes a complete engine harness for 97 Obd2a Del Sol with 94 Obd1 GSR swap. I know of one place that makes the harness but it is not the whole harness, just a sub harness. Or if anyone know what my problem can be. Thanks
it is not hard to do an obd1 in a obd2 civic the only problem is some of the ecu problems but if you wire everything right you should be good!
Where can I find a wiring diagram for the car and the engine? Also would it be easier to use an OBD2A GSR ecu in the car or what problems will I run into? I sick of poking and hoping......if you know what I mean.
Yes I am putting a OBD1 engine into a OBD2A car......I live in South Carolina where there is no emissions law yet..
