engine options
Discussion in 'Engine Building' started by honcrx91si, Apr 1, 2004.
  1. honcrx91si
    honcrx91si Junior Member
    i have a crx si with stock motor... my head gasket is leaking and i am tryin to figure out what i wanna do... i wanna either fix my engine and get new cams.... or get a v tec head... or get an ls motor i heard the 90-93 teg ls work with all the stock wiring i just need new engine mounts.... if that is true i would think that would be the better opinion...i don't really have alot of money to do the wiring converstions either like from obd0 to w/e... so if u could give me alittle feed back and give me your opinion on the engine choice that'd be great.. yea.. anyone could throw a few pros and cons in there if you'd like too.
  2. pissedoffsol
    B16 SiR swap sounds good to me :)
  3. Import Builders
    Import Builders Senior Member
    LA, California
