engine sleeves
reavem
gyus im new in the forum so i will go fast to what i wanna know
i got a h22a engine that i got from japan very nice and clean to use forget pistons it is necesary to sleeve the block of the engine or can i use the stocks ones.
Total truth above. Jun also makes pistons that work in the H22, but if you live in the US, go with Mahle, much easier to get and very similar performance.
If you wanna use JE or some other piston in the H22, you will DEFINITELY need to have the block sleeved.
damm gyus tanks a lot for give me a couples of ideas to save some money and time.. i just got another question for any reason do you guys know how much can cost to have my h22a resleeve.....
You can probably get some MID sleeves installed for around 1200-1500 bucks assuming you're using someone you've never used before.
Press in sleeves are gonna be a bit cheaper in the around 800-1k range.
