Engine swap into an EK...
Discussion in 'HYBRID -> EG-EK / DC' started by Chesh, Mar 18, 2009.
  1. Chesh
    Chesh New Member
    I'm about to do my H22a swap into my EK and just want to make sure i have got 100% everything before i start ripping my current engine out.. this is what i have:
    -H22A Engine 70,000 miles (with all the little bits.. like starter motor, etc)
    -Gator H22/EK Drive shafts
    -H22 EK Hasport mounts
    -H22a7 Accord Type R Intake Manifold
    -H22a7 Accord Type R LSD Box
    -Shifter box and cables
    -EK VTi loom
    -AEM Hybrid H22 EK cold air intake
    -Full Apexi N1 exhaust
    -H series mani to fit EK, with a decat
    -Stage 2 clutch
    -EK VTi hubs
    -262mm brakes with slotted disc's
    Also could you give me a list of the service parts i need please.. at the moment i have:
    -Hamp oil filter
    -Hamp fuel filter
    -Engine/Gearbox oils
    -Timing belt
    if you could let me know what else i have to buy engine and service part wise it would be a great help as i only have one car and dont want to ruin my swap by forgetting something
    any help will be much appreciated
  2. tabKola
    tabKola New Member
    Tewksbury MA
    If you are going to change the timing belt then you should also change the water pump. Also could not hurt to change the plugs and wires.
  3. austin20110
    austin20110 New Member
    Northern Va
    You have to do that to get the warranty anyway..
    We in for a build thread anytime soon??
  4. BrokenRex
    BrokenRex New Member
    oh i hope so. i plan on doing this soon, and would love to see the hurdles you encounter and how you overcome them. one thing i think you need is a resistor box for the injectors. not sure on that, can anyone verify?
  5. Chesh
    Chesh New Member
    yeh ill take pics and will do a build up :)
    so engine wise does it look like i have everything?
  6. Chesh
    Chesh New Member
    ^ and about the resistor box i have one of them aswell
  7. doc500
    doc500 New Member
    don't forget the emissions controls if you want to pass smog/ bar.
