There is usually abot 10% ethanol added to help emissions in some cities, especially up north. It can lean the engine slightly when in open loop ( more ethanol (or methanol) is required for stoichiometric mixture) but this is usually good as stock motors tend to run a bit rich anyway.
Bad thing is ,alcohol absorbs water and can then seperate from the gasoline. Even if it doesn't, the water content can cause corosion. We never store engine's long term with gas/alcohol mix in them.
The fuel suppliers combat these problems with extra corossion inhibitors and other additive to keep it in suspension..
