anyone here ever swap a complete OBD1 harness into an OBD0 car?
i'm in the process, been taking quite a few pics, and it seems to be working out ok so far...
VSS actually fits with modifications
and appears to work... rotate trans input shaft and the VSS turns, so i'll assume its working...
need to wire up the fuel pump and then drop the motor in for test run...
anyone here ever put a 92-95 civic cluster in a 91 hatch? i think i saw pics on here once...
