F/s B series parts
Kolumbo69
All prices in canadain, I will convert for the part you need.
B20b stripped down cleaned,$900 ( comes with all b20 parts that cam with it)
B16 short block $400
B16 head with arp head studs, 2000 itr cams with 20,000K(on cams)$1300
Arias custom pistons set 11.8:1 comp with rings and pins$900
B16 S1 tranny,$500
Cluch master b seires fly wheel (10lbs)$500
Ef avid mount kit $400
Fuel regulator$65
cr/vtec head gasket$100
255L honda fuel pump kit$140
new water pump$100
new timing belt$60
new rod bearings$ 60
Cr/vtec conversion kit$ 200
eagle H beam rods$550
avid ef shift linkage$180
obo0 hondata stage 3 $785
sir axles$200
Enkie tbs1 rims with ziex tires$800
Buyer pays shipping as an extra on to the price.
I live in calgary canada , pick up prefered. Everything except for blocks and tranny sir axles and rims/ tires, are brand new in box.
it would be 45 us for the timing belt, the water pump is from the people that distribute to honda the water pump. The tranny is cable and would be 375 us.
