f/s ls motor and tranny 800
Discussion in 'Parts: For Sale/Trade/Wanted' started by dok, May 26, 2005.
  1. dok
    dok Senior Member
    ok the swap is in a 94 teg its a obd 0 b18a1 but it has a obd1 dizzy so it works it also has a cable tranny but it has been converted to hydo so if you have a 88-95 hb this will work perfect call me if any ? 773 403 1870 tony may trade for pats for a teg let me know what you guys have
  2. dok
    dok Senior Member
    up up and away
  3. CoreyR
    CoreyR Senior Member
    so let me get this straight, its an OBD0 AND OBD1. it also has a cable tranny but its also a hydro tranny and it will work in both obd0 and obd1 cars with cable and hydro tranny setups?
    so what are you selling here?
  4. civic92jak
    civic92jak Senior Member
    ok, from what i understand and know, its an obd0 motor converted to obd1 with the OBD1 Dizzy. ANd the trans is a cable trans, but with the hydro conversion kit on it. So, you can change the distributor back to obd0 for the 88-91 civics/crx and take off the hydro kit to allow for cable use in those vehicles. That help ya?
  5. dok
    dok Senior Member
    thanks civic92jak that is what i meant glad some one understands what i am talking about
  6. civic92jak
    Man, i'd buy your swap if i had the cash. I'm only 3 hours from ya also.
