f1 car warm up
holy shit. when it was at idle for a while i thought he had it on half throttle or something.
and B guess those EGT's, lol
that motor spins up so fucking fast...
its just unbelieveable...
damn
:drool:
it sounds so nasty...
i need one
no, make that 2
You could cook marshmellows on that thing! :lol: Oh and it sounds cool.
thats an orange arrows block from a couple of years ago. thats not even on the better half of the grid. but thats just to show that even the ones that suck on track can make us fall in love. nice video.
HOLY DAMMIT CHRISTMAS THAT'S HOT.
Reminds me of the 4-rotor mazda lemans car vids.
:wub:
[post=479120]Quoted post[/post]​
i can't even imagine.... fucking hot.
imagine how hot hell is, and then look at that exhaust. lol
no doubt...that was sick as hell! his egt's are probably over 1500 degrees.
hotter then that. a lot of turboed cars can have egts around 1500F easily. unless you are talking about celcius, lol. in the other thread about the supra blowing up, B said he saw EGT's around 825C thats about 1500F.
I've witnessed stuff like this is person, and it's absolutely amazing. The CART races have been in Denver for two or three years now, and it's just amazing to first watch them warm up, then go balls-out around that track. Listening to those engines is pure sex. :)
heres some info to put into mind
Some interesting Top Fuel dragster facts:
* One dragster's 500-inch Hemi makes more horsepower then the first 8 rows at Daytona
* Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per second, the same rate of fuel consumption as a fully loaded 747 but with 4 times the energy volume.
* The supercharger takes more power to drive than a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly-solid form before ignition. Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression-plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting off its fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in those cylinders and then explodes with a force that can blow cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this sentence.
