F22 into 92 civic
Discussion in 'HYBRID -> EG-EK / DC' started by eatsleepf22, May 24, 2008.
  1. eatsleepf22
    eatsleepf22 New Member
    hello guys im new to the forum...and i wanted 2 know all the neccessary things ill need to complete this setup..ima list the things i found around that i need
    h22 motor mounts
    90 to 93 integra axles
    what else its there 4 me to know plz im very excited about this swap cuz i want a lighter shell and a civic hb will be perfect .....
    oh and what transmission should i use ......and all the wirin that ill need
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Do you have the F22 already? If not, I would suggest an H22 instead. The entire swap can be had very easily. If you already have the F22, then by all means, I wish you the best and want to know how it turns out as I don't think I have ever seen an F type in a Civic before.
  3. eatsleepf22
    i already have the f22 engine al bored with compression pistons fuel rails beehive valves cams...camshafts the big deal
    I wanna know what i need to put the f22 into a 92 civic hb...plz everythin will be perfect if listed
  4. Luis998
    Orlando, Florida
    I am really sorry my friend. If it were a D or a B I might be able to help you. An H I might guess along but I know nothing of the F's besides that they usually reside in Accords. All the best to you. Research is going to be your best friend. I would suggest calling up a shop and seeing what they say. Good luck.
  5. Luis998
    Orlando, Florida
  6. hondarin
    Texas; where else?
    it would be just like putting an h22 in there.
  7. disordinate
    disordinate Technician
    NY
    Agreed. Its just like puting an H series into your civic. I don't exactly agree with it for a street car bacuse it causes handling changes. but to wach thier own.
    H swap mounts should work, aswell as the shift linkage and aswap axles. If I where you Id look into companies like Hasport. not 100% sure if thiers any difference between the H axles and The F axles. but Hasport has swap stuff for just about any Honda swap out thier. I know for a fact they share the same mounts and linkage though. If I where you I would get an H tranny, or (even more ideal) get An HtoB plate and pick a B series tranny of you choice. Besides that, youd need an H22 ECU, an H22 engine harness. If your hatch didn't have vtec already wired you either gotta wire it yourself or again hasport. I know the have harnesses for B-series into a non-vtec shell. I'm sure they have the same for an H. O, and on the tranny mount( I heard hasport may have come out with a mount to solve this problem but i haven't seen it yet) you gota modify the mount on the chassis to make the mount fit. Some people cut it off totally and make a new one, some people cut it down and drill new holes for the mount bolt. I think that's all youll need. If I missed anything i'm sure someone will say so. Good Luck on your swap
  8. Adeel
    Adeel New Member
    Hey there, go to hasports.com... they have all the required mounts, axles and shift linkage required for any swap... I hope this helps you out... The mounts are a lifetime warranty...
  9. Dark93DX
    Dark93DX New Member
    B.C.
    :werd:
    If you dont wanna cut anything you can do an F2B swap, your F-series engine and a B-series trans. Not sure if there is an F2D swap avaliable yet though.
