f22 with h22 tranny
miller9779
I just put everything together but the motor won't turn over. I'm using the starter from my f22. is there anything I need to change? what am i doing wrong? its gotta be something with the starter!!! Is the H22 starter a different size? this is an f22a1 with an h22a trans. Any help would be appreciated, thanks. - mil
Ok i'm an IDIOT >>>>>>>motor IS turning over. But i don't think i'm getting a spark. pulled a plug and checked for spark = nothing. Can someone help me diagnose this? should i get a new dizzy? ahhh <-n00b thanks. -mil
u can get a new dizzy from the distributorking.com for like 150 or so... or you can replace everything, coil, plug wires, icm, cap, rotor, plugs
Odds are it's a wiring problem, unless you have reason to believe the distributor would be bad. In the FAQ's there's info about the distributor wiring.
