f22b1 in integra
Discussion in 'HYBRID -> ED-EF / DA' started by stichedskater, Mar 18, 2004.
  1. stichedskater
    stichedskater Junior Member
    i wanted to know if i can just put in a accord sohc f22b1 in a 1989 integra and what i need to get so it could work right plz answer the reason i want the engine is cause i have no engine in the teg
  2. rushcrx
    rushcrx Senior Member
    Pittsburgh, Pa
    hey man i really dont think that is worth it honestly. I mean i noticed that you dont have an engine in your teg yet but the $ you are goin to drop on a sohc swap would be umm ?????? Well all I can say is if you are dead set on this you are probally going to need mounts linkage axles/mod and the basics ecu tranny ect. but maybe save your pennies and get a h22a1 dohc vtec :D and you will have way! more fun driving your teg. :thumbsup: Well whatever you decide to do keep us posted man. good luck!
  3. brian11to1
    brian11to1 Senior Member
    ok, first off, an F series into a 89 and older Teg would be awesome. Hoever there are downsides.
    Those being:
    OBD conversion
    Shift CABLE conversion (from linkages to cables, search about how the accord/prelude change their gears)
    Mounts Will be custom and may cost a lot.
    Thats about it, as far as I can think of.
    Good luck, Brian
