feul pump/ecu trouble
B16Ablacky
honkey tits
i just dropped a jdm b16a into my 91 integra gs. everything is hooked up mechanically and electrically, or so i think. i used the obd0 to 0bd1 coversion from rywire.com. now when i finally with the swap i tried to start the car and it would turn over but no start. i later found out after some tests that my fuel pump wasnt turning on and i was getting no spark. then i just 2day tried putting my old obd0 non-vtec ecu back in place and turned the key and my fuel pump turned on but i still got no spark. what are some possibilities on what my problem is? i was thinking maybe the new ecu(pr3) i somehow "bad" or the ecu jumper harness is "bad."
any help is much appriciated
