Fidenza ???
Discussion in 'Engine Building' started by xj0hnx, Mar 30, 2004.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Anyone using their cam gears? ANyone know of any horror stories with their cam gears? Anyone have their website, I can't seem to find it.
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    never heard of anyone using the fidanza cam gears.
    I knew they were out just never got to that point with my old motor, if I were to recommend cam gears I would get the ones that can't be adjusted for more than 5 plus or minus degrees.
  3. xj0hnx
    C.C.TX.
    This are the ones I am talking about....
    I am about to buy them, but I just wanted any last minute, "wait no"s, or "good score"s, you know.
  4. JDMilan
    Boca Raton, FL
    hmmmm. it's up to you, I personally would only use toda's, but thats me.
    I mean, chances are that you will tq down the bolt enough so that it won't slip, and if the price is right - get it.
  5. xj0hnx
    C.C.TX.
    One guy who has them said the torque specs are 7-14 inch lbs :huh: Doesn't seem like a lot of hold.
  6. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    a kid i know has them on his b16. he hasnt had any problems with them. putting locktite on the bolt threads ensures they wont loosen either. 5 bolts should be good. I have skunk 2 cam gears, just bought them tonite, they are 6 bolt.
  7. JDMilan
    Boca Raton, FL
    the more bolts the better, i would assume.
    yeah, I know the ft lbs isn't much but it's critical to have them TQed to spec. Problems happen when you lighten or over do it.
