Finally making it look nice...
3" Dump
nice and smooth now :) she's getting there. why the drivers side though? i would have piped it out the passenger side
Here's some updated action... Clear-coating it tonight.
Filler primer sanded with 400 grit.
Value shade 7 sealer primer
Purple with Marlin effect on bottom
Marked pin stripe and division of the top color (black)
Painted the top Pearlescent Black
Taped off pin stripe's permanent location
Painted the blue part of the pin stripe
I'll get a shot of the silver pinstripe after i take all the paper off. Tonight I am painting on the prelude emblems i made. a friend of mine does decals for a living and he let me use his software.^_^^_^^_^ Also clear-coat tonight...
Can't wait to see it. Looking good.
What's the under hood situation? Is the H built or stock? What turbo? hp? That kind of stuff.
Pictures look a little dark for some reason...but anyways...
^_^:cool: I'll post engine spec's tomorrow!
nice, any pics that you can see well?
Golden Eagle sleeves w/ copper o-rings, Eagle rods, Aries pistons 9.0:1, ACL rod and main bearings, OEM headgaskit, Stock head. H23 manual tensioner, greddy timing belt, Fidanza flywheel, ACT 6 puck sprung clutch w/ heavy duty pressure plate, Garrett T3/T04 60 Trim .82 A/R turbo, Synapse Waste Gate001, Revhard Exhaust manifold, Skunk 2 intake manifold ported to fit a BLOX 76mm Throttlebody, Greddy BOV Type RS, Stock JDM LSD transmission. PLX wideband, Tuned with Hondata s300^_^
I built the motor 2 years ago and its still running strong :ph34r:
