WV Finishing my honda and acura partout lots of stuff, tools etc
Discussion in 'Parts: For Sale/Trade/Wanted' started by tofasttoslowforyou, Oct 18, 2009.
  1. tofasttoslowforyou
    tofasttoslowforyou New Member
    LINK TO PICS:
    Flickr: sand in my va-ja-ja :)'s Photostream
    call or text 240 329 1165
    or pm me
    Can list it on ebay for a few buck xtra.
    Shipping to canada is gonna be xtra but I will ship to you.
    IF YOU USE PAYPAL I ONLY ACCEPT IT IF YOU HAVE A CONFIRMED SHIPPING ADDRESS. THIS IS NON-NEGOTIBLE.
    Text me or call me 240-329-1165 for paypal info or message me on the forums.
    PARTS ARE IN MARTINSBURG WV 25405
    I AM LOCATED IN MARTINSBRUG WV 25405
    dsm shit:
    Just a couple of dsm parts left
    only take paypal or pickup
    items are in martinsburg wv
    2g maf filter adapter wit filter
    13 shipped
    2g o2 housing with no o2 sensor no cracks
    13 shipped
    88888888888888888888888888888888888888888888888888888888888
    honda stuff:
    -craftsman 12 point 1/2in drive sockets not seperating the sets sold as all standards or metric
    see pics for sizes
    NOT PARTING OUT THE SET
    new never used
    15 shipped for metric and 15 shipped for standards
    Fair price since ther not light and i am shipping them and they retail for more each and the have lifetime waranty
    -box o bolts and nuts ranges in size from 8mm to 19mm tranny bolts axle bolts etc...
    13 shipped its bout 15 pounds lol
    -dounut gaskits new
    5 shipped for both
    -exhaust rubber hangers
    15 shipped for all
    -optima red top battery was out of a 90 integra i had works great
    NO SHIPPING ITS WEIGHS TO DAM MUCH
    30 picked up NO SHIPPING
    -driver and pass side dc 94-01 teg windows
    10 both picked up
    no shipping its glass duh
    -del sol seats black red strip no rips or tears
    130 picked up firm
    -new engine stand used for a little but dont need it
    NO SHIPPING IT
    30 picked up firm NO SHIPPING ON IT
    -eg ac seals new opened to use a few dont need it
    5 shipped for all thats left
    -94-01 teg rear trunk carpet not stained but cut for cd player in trunk dont need it
    13 shipped
    -21mm honda lug nuts 15 are good one is questionable
    10 shipped
    -plug in angle grinder new never used metal cut off wheel its a craftsman and still works
    23 shipped for both
    -spot lights needs bulbs not shipping it its not light
    25 picked up
    -gsr oem water pump housing and pipe obd2 parts
    13 shipped
    -inner door handles for dc teg
    10 shipped for both
    -flywheel bolts for b series, half shaft bolts for b series and clutch bolts for b seires
    15 shipped for all
    -gsr oem header has light dent and few scratches
    10 picked up not shipping it
    -GSR oil pump used no spun bearings sold the bare block and head so i have this left over its a obd2 oil pump oem part has 80k on it. good pump not a junk one
    15 shipped
    -gsr main bolts stockers pulled from a 80k motor sold bar block and head all thats left
    15 shipped
    -gsr pickup tube not trashed oem sold bare block and head got this laying around
    15 shipped
    -oem gsr water pump used 80k no probs parted out motor all thats left
    10 shipped
    -oem timming pully with bolt belt and this was replaced 20k ago parted out motor all thats left comes will all bolts etc
    10 shipped
    -oem rear main seal b series part
    10 shipped
    -oem new front main seal new from honda in bag
    10 shipped
    -96 oem crank angle sensor works no need for it
    10 shipped
    -b series timming pulley non obd2!!
    10 shipped
    -crank wooddruff keys have about 5-6 and 1 b series cam one
    2 bucks shipped each
    -b series crank bolts non stripped
    10 shipped for all
    -cat guts, off a oem 94 gsr cat, some got melted idk what its worth dont need it wieghs about 2 lbs. recylce/scrap use only
    10 shipped
    -head and tranny dowel pins have like 4-5 of them
    10 shipped for all
    -oil presure sensors for gsr motor, should work on all b series
    10 shipped for both
    -b series hydro reverse switch works dont need it
    10 shipped
    -coolant jug for dc teg and eg civic works no leaks
    10 shipped
    -98-01 pass side headlight for dc teg works no cracks and oem
    45 shipped
    -itr center consol delete used but in great shape
    25 shipped
    -gsr cloth seats fron only dont need em a lil dirty no rips or tears head rests are included not picd though
    30 picked up for both
    -ls transmission hydro parts all parts have 90k on them complete shifter base and other parts semi complete 1st through 4th only no 5th gear parts, dont believe i have 3rd gear set or syncro,and sleeve. counter shaft and main shaft and stock open diff ls diff, all parts are used but in great shape
    *will part seperatly pm me
    30 shipped for all of the ls hydro parts diff, shifter base and forks and gears 1,2,3? not sure if its there and 4th
    -oil pan bolts all are there but i think one or 2 all 10mm nuts and bolts.
    5 shipped
    -cable b series vss
    15 shipped
    -b series 94-01 gsr half shaft
    30 shipped
    -b abd d alternators and b series only starter, 3 alts and 1 starter all work 15 shipped each or 20 picked up for all 4or 5 total
    -gsr lower cover mid peice is missing that goes from the head to mount facsing you he peice in the far right back in the pic
    15 shipped
    -rear tbracket off a dc perfect for b swaps into eg/dc/delsol
    30 shipped
    -itr 5th More pics to prove it came out of a itr trans as i still have the trans
    25 shipped?
    -cable trans slighty used clutch oem has half life left
    22 shipped
    -94-01 turn signal brackets to hold them dam signals in place.
    10 shipped for both
    -dc teg turn signal pass side onle in clear.
    5 picked up
    -new in the box sirius satellite radio
    comes as shown never been used only opened once for pics.
    50 pickedup
    -96 gsr ps pump worked great
    13 shipped
    -gsr etc knock sensor in working order parted off a block I sold
    30 shipped
    Not shipping the front bumper
    98+ dc2 front bumper
    this one has 2 small tears/holes
    a small rip here thats 4 in?
    nicked here near the emblem
    25 picked up
  2. tofasttoslowforyou
    ttt
  3. tofasttoslowforyou
  4. dzminiz
    dzminiz Junior Member
    Martinsburg, wv
    Fuck me for not remembering to get my redtop back out of the DA
    lol
  5. tofasttoslowforyou
    you want it 20 and take it
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    I bet I need like 10 different parts from you, but I don't want to spend 20 minutes reading to find out! lol
  7. tofasttoslowforyou
  8. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    i need a few tranny bolts and what not. the $13 shipped box-o-bolts, what all did they come off of? i might be super interested. u nvr know when u need extra honda bolts lol. i need 3 tranny bolts for a friend and we cant find the proper thread type and size anywhere. pme me tofasttoslowforyou i wanna talk bout these haha.
  9. tofasttoslowforyou
    that box is sold
  10. nwkdonblk
    nwkdonblk New Member
    oakford il
    do you still have the b series starter
  11. tofasttoslowforyou
  12. 95EGCoupeVtec
    South Mississippi
    you should take it off your list of parts so no one else will try to buy them since u don't have them anymore. just a suggestion. :D
  13. tofasttoslowforyou
