FMU
Discussion in 'Forced Induction' started by calvin, Oct 16, 2002.
  1. calvin
    calvin Senior Member
    NETHERLANDS
    Is an FMU(vortech,comptech) a must if you turbo your civic???
  2. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Get the Greddy FCU its already programmed for turbo.
  3. turntune
    turntune Member
    Boca Raton, Florida
    it depends on how your doing your turbo setup...if your replaceing the ecu for a programable one..no
    if your adding larger injectors with an s-afc or fields controller...no
    if you running stock injectors and fuel pump...depends on boost and turbo size..but safe to say yes
    Knowledge, I hope Greddy cuts you a check for all the advertising you do for them ;)
  4. pissedoffsol
    going the fmu way is the cheap way out- and IMO, not a good idea if you care about reliability
  5. knowledge
    Beale AFB, CA
    Lmao Turntune! I should talk to them about that! I could be their poster child! lol
  6. turntune
    turntune Member
    Boca Raton, Florida
    I agree with pissed on this one.....the fmu route will have you breaking something...at the VERY least run larger injectors if your going the cheapo route!
    but doing it right the first time pays in the long run
