up for sale is a xspower gt35 duel ball bearing turbo...here are the specs on it...this turbo is pretty much new has 0 miles on it and will come a obx exhaust flange...and for the right price i will throw in the manifold and a no name waste gate already together ready to be put on...let me know if you are interested and i will post pics up GT35R Dual Ball Bearing Turbocharger 700 Capable Ball Bearing Center Housing - Spool Quicker and Improve the Reliability of High Output Turbos Sealed Aluminum Housing T3 Gasket and Drain Gasket Included 4 Bolt Flange Outlet T3 Flange Inlet 2.5" diameter Inlet Compressor Wheel Exducer Diameter: 82mm - 56 Trim Compressor Housing: .70 A/R Exhaust Wheel Inducer Diameter: 68mm - 84 Trim Exhaust Housing A/R: .63 3CR13 Seal Rings GT35R turbo T3. Dual Ball bearing turbocharger unit. .70 compressor and .63 exhaust side, 4 bolt Exhaust side. Compressor Specs: T04S 56mm compressor wheel 0.70AR T04S compressor housing Flow Rate 65lb/min Turbine Specifications: 84 Trim 68mm .63 A/R. turbine housing CHRA Specifications: Full steel ballbearing cartridge. Oil & Water cooled&lubricated center section.
i will post the pics up tomorrow i have to upload them to the computer...i just got off of work and am too tired to do it tonight
