me said:the first two snare fills are a bit offtime, they could be a bit smoother...also the fills during the 'don't imagine' part (im guessing its the chorus) are a bit repetitive, not TOO much, but they don't vary a lot from each other...i really like the part where it's just hi-hat and an occasional kick in the very end. other than that, the only thing I'd do different is maybe in the very beginning go half-time on the hi hat, and use the ride during the chorus...the hi-hat through the whole song makes it a bit harder to distinguish the chorus from the verses...as far as the sound of it, the kick isn't quite as punchy as I'd usually make it - it's somewhat hard to hear the kick over everything, could use some more low-mid on the kick in the mix. I also don't like the mic placement on the snare, it's a bit too dry for my taste, sounds far away, and sounds like whoever mixed it put some reverb on it to try and compensate...another thing I'd do if I were you is put something like a moongel on the snare to get rid of some of the ring that it has (stands out more when you can hear the snare by itsself). The only other thing I notice is the hi-hat sits a bit high in the mix, could be pulled back a bit.
I usually have my mic ALMOST parallel with the head of my snare, but pointing right at the spot where the stick impacts the head. I play with a TINY kit, and everything's pulled in REALLY tight, but if you work with it you can get it in there. For recording, the only time I'd ever mic the inside or the bottom of the snare is as a secondary mic (which actually will give you a lot more versatiliy in mixdown, and will make getting a good tone a bit easier). I usually run an sm57 on the top of my snare, sm57 on the rear of the kick (pointed at the point where the beater hits the head), and a D112 inside the kick, about 6" back from the back head (impact head), in the center of the drum, pointed at the spot where the beater hits the head. In mixdown I mix the front mic with just lows and low-mids, and the rear mic with just highs and high-mids. I used to run a 57 under the snare too, and mix it the same way I mixed the kick, but over time I figured out how to position the snare mic to get the sound I want. I still use 2 kick mics because it allows me to make it REALLY punchy. This was all taught to me by Tom Pierce Baker, a guy I used to work in the studio with who did work on Pantera's first 2 albums, among several other rock/metal bands (and, if you ask me, is one of the most ingenious people in the industry).
For those who wondered, my recommendations:
