Front Disc Conversion
Bl6CRX
Hey, my 91 CRX HF doens't stop worth, well you know...but anyways I was wondering if I could do the front disc conversion from a 90-91 integra if I used the full brake assembly, rotors calipers etc, and changed the master cyclinder to the 90-91, has anyone done this or is it possible, and is there any parts one would not think off hand, thanks...
yes you can, but the integ knuckles give you bad camber. I think it gives you positive camber, but I'm not sure. If you could get a set of 90-91civic EX knuckles. you would be set. everything from the civic to the integ is the same, except for the knuckles.
isnt the suspension relatively the same, if it is then go ahead and buy it from me then find those knuckels
