FS: 1994 Honda Civic Ex in Upstate NY
baker423
1994 Honda Civic Ex Coupe
218k on stock SOHC d16z6 vtec motor w 5spd transmission
VIN avail. upon request for serious inquiries
Clean title
Power windows/power locks/power mirrors
Power Sunroof
Power steering
Cruise Control
The good & New parts replaced within the last year:
Front brakes, Aug.05
Rear Brakes, Jan. 06
Brake Lines in Jan. 06
Clutch, Jan. 06
Tires in Aug 05, 85% tread left
Poly Bushings in Front Control Arms in Aug. 05
Interior is clean, no rips or tears.
Body is in good shape for a Civic this age. There is NONE of the Typical Honda body rot, the car has not even begun to rot through. Car is not from NY, which explains the decent body on it. The only rust on the car is the surface rust that has just barely started. The body is solid and the quarter panels have never been retouched or reworked.
The Bad:
Check Engine light is on due to a faulty O2 sensor, minor problem and does not need immediate attention. Car does have a valid NYS inspection.
There is a dent and scrape on the passenger rear quarter with a small amount of surface rust just starting.
Front axle may need to be replaced.
Sunroof motor is weak.
Car is completely stock. I bought it from my cousin to use as a daily driver with plans to drop my b18 into it. I no longer wish to do that, i currently have 3 cars licensed, registered and insured on the road and i cannot afford to continue to do that, so this has to go.
Car runs solid, shifts smoothly and is a perfect candidate for a swap.
Contact me via Pm or email.
Vehicle is located in Lansing, NY 14882.
$2500.00 OBO
Free <span style="font-size:24pt;line-height:100%">BUMP</span> for a NYSPEEDER
someone jump on it.
GLWS. :mrgreen:
