IM PARTING IT ALL OUT im leaving the head on the block so dont bother asking for the head i have a b16a with type r cams ctr crank pulley skunk 2 cam gears skunk 2 intake 74 mm throttle body golden eagle fuel rail full msd ignition with dizzy s200 tuned for the b16a 7 or 9 lbs flywheel stage 2 clutch tranny has the mixed gears from the ls and sir b16 tranny for the better gear ratio hasport mounts pacesetter exhaust rsr header jdm style racing cat rebuilt bottom end gsr dash with gsr cluster in it working i really cant think of anything else.....but you would be lucky to get a full b16 swap with ecu axles and everything for 1400 so i think its a fair deal...its sitting in a 89 ef right now... you can have the whole shell i have alot extra parts for it....its not running right now cause the fuel pump is not turning on and the the tail lights turn on when i plug the battery in so it has to be the wiring harness in the car .....if you dont want to pay what i ask then dont buy it....if you want to call me my name is adam and my phone number is 412-401-1511......NO LOW BALLERS.....serious buyers only please....engine has over 200HP civic crx del dol integra civic rsx prelude honda acura b16 b16a b16a1 b16a2 b18 b18a1 b18a2
