FS: Built NA GSR Motor Set
onesikdb8
Member
FS: Built NA GSR Motor Set - $5500
As the title says, For sale is a Built NA GSR motor Set which includes and has the following done:
B18C1 Longblock:
CTR Pistons
Shot peened GSR Rods
ARP Mains
ARP Rod Bolts
ARP Head Studs
Factory Honda Headgasket
Power Enterprise Timing Belt (Blue)
Ported GSR Head
Buddy Club Valve Springs
Manley Titanium Retainers
Buddy Club Spec IV Cams
Buddy Club Gold Cam Gears
Type-R Valve Cover with Laser Cut Moon Cuts
Middle Timing cover with Laser Cut Moon Cuts
New GSR Oil pump
Longblock assembly was Cryoed
Hondata IMG
Skunk2 1st gen Intake Manifold
Spoon 70mm Type-R throttle Body
Type R Throttle Cable and Bracket
AEM Silver Fuel Rail
AEM Silver FPR
RC 310 Injectors
JDM Type R Header Jet Hot Coated
JDM Type R Upper and Lower Heatshields Jet Hot Coated
Type R Donut Gasket
Factory Motor Mounts
Engine Harness
P72 socketed for Hondata S300 - Needs to be tuned
Factory GSR Shift Linkage with Short shifter
Polished GSR Distributor
Will sell the complete motor set with all the above FOR NEW LOWERED PRICE $5500
the motor only has around 13,000 miles on it. It was rebuilt a little over 2 years ago and hasn't been driven that much
Perfect motor for circuit
Stock GSR NON-LSD transmission
ACT HD Pressure Plate
ACT Street/Strip Clutch Plate
ACT Prolite Flywheel (8.8 lbs)
Will also come with Alternator, Power Steering Pump, and A/C compressor.
interested
located in fairfield,ct
i bought a 99-00 obd2 si swap complete. took it all apart and lubed etc.
long story short, replaced the chasis, bigger brakes, everything, not nowing
that in order for that engine to run in my car i would have to send the harnesses to hasport and all this shit, so i have to sell this swap to somebody and am interested in buying the b18c1 only if it is obd1. feel free to leave a message.
