FS: D-Series Inventory Reduction & More (SC)
Discussion in 'Parts: For Sale/Trade/Wanted' started by tmitbyh, Oct 1, 2007.
  1. tmitbyh
    tmitbyh Member
    Sumter, South Carolina
    I have way too many d-series parts lying around and need to get rid of them for various reasons. If you have any questions comments or concerns post them in here or shoot me a PM. I will answer any and every question as best as possible. Also all items were removed from a 1995 Honda Civic EX Coupe unless other wise specified. I ship most items USPS via a Flat Rate box so shipping charges are constant for items that fir into those boxes at $8.95. If you see something you like, want, or need, but don't like the price, please make a reasonable offer.
    PayPal: PayPal at tmitbyh dot com
    Email: JB at tmitbyh dot com
    AIM: tmitbyh
    ICQ: 16687842
    MSN: JB at tmitbyh dot com
    Yahoo!: tmitbyh
    Phone: Can be provided.
    Kicker Comp VR Subwoofer and Q-Logic Box
    I had this in my Civic for a while and it worked perfectly in there. I took it out because the car became used for track only duties. The sub still works great, but is a little dusty from sitting in the garage. The box carpet is a little beat up on the corners but nothing that is going to degrade the box integrity or quality.
    Price: $50.00 (Picked Up) - Willing to ship
    92-95 Honda Civic Coupe Blower Motor
    When I gutted out my car this was one of the many items that were pulled. The motor its self is in perfect working order so you would not need to swap out your plastic box to use this one.
    Price: $15.00 (Picked Up) $30.00 (shipped)
    92-95 Civic Cruise Control Module
    This is another item that was removed when the car was gutted. The cruise control on the car worked great before everything was removed.
    Price: $10.00 (Picked Up) $18.95 (Shipped)
    92-95 Civic AC bracket & Tensioner
    This is another item that was removed when the car was gutted. Everything you see is included with this item. It will need a new mount however as you can see from the photo. Everything else about the bracket and the tensioner are in perfect condition.
    Price: $15.00 (Picked Up) $23.95 (Shipped)
    92-95 Civic (D16Z6) Cam Shaft & Gear
    This is a spare cam and gear I have laying around. I am trying to reduce my inventory in preparation for a possible move among other things. The cam shaft is going to need to be machined as it has developed some surface rust on the lobes from sitting so long. Aside from that it is in good shape.
    Price: $20.00 (Picked Up) - Willing to ship
    D16Z6 Bare Block
    This is one of two spare blocks I have laying around the garage. Again this is in an effort to reduce my inventory. The block is going to need to be machined as surface rust has developed in the cylinders from sitting around. Aside from that the block is in good condition with no cracks in it. It does not have an oil pan and how you see it is how it will be sold.
    Price: $50.00 (Picked Up) - Prefer not to ship
    D16Z6 Block
    This is the second of the two blocks I have laying around. As before this is in an effort to reduce my inventory. This block looks good in the cylinders and has a set of P2P pistons in it. It does have an oil pan on it as well and an alternator. As before how you see the block in the pictures is how it is being sold.
    Price: $75.00 (Picked Up) - Prefer not to ship
    Mazda6 Wheel
    The wheel is scuffed up and has a few nicks but it still straight. It can easily be sent off to some where like Wheels America and be refinished for a decent price.
    Price: $45.00 (Picked Up) - Willing to ship
    96-00 Civic Driver Seat Bracket & Slider
    This with my set of Ronin style seats when I traded for them and since I do not own a sixth generation Civic they never got used. I attempted to use the slider however the previous owner cross threaded the bolts and I simply gave up on trying to get it out. It could easily be removed with a set of Vise Grips or something similar or maybe even tapped again once the bolt was removed.
    Price: $10.00 (Picked Up) - Willing to ship
    Honda Single DIN Pocket
    This was removed from a 96-00 Civic but was used in my 95 Civic just fine in the single DIN space. It should work in any single DIN space of most Hondas.
    Price: $5.00 (Picked Up) $13.95 (Shipped)
    92-95 Civic Under hood Fuse Box
    This was removed from one of my donor cars and I have no use for it. It is the fuse box that is located under the hood of the 92-95 Civics. This particular one was removed from another '95 EX coupe.
    92-95 Civic Driver Side Seat Rails and Sliders
    This was taken out of my donor car as well and is in working order. I have no need for them as I have a fix mounted seat in my car on an aftermarket bracket.
    B18B1 Throttle Body
    I have had this laying around for a while now and no longer need it for anything planned. It is a stock B18B1 throttle body.
  2. tmitbyh
    tmitbyh Member
    Stock Honda 240 Injectors
    I cannot recall what engine these came out of but they are stock 240 injectors. These would be a perfect candidate to be sent of to be balanced and blueprinted.
    Price: $20.00 (Picked Up) $25.00 (Shipped)
    P29 Standard Pistons
    I purchased these brand new and never used them. I moved them around and that has been about it. All four pistons are still in the sealed plastic bags and in the original box with everything they came with. I am no longer pursuing the build these were intended for so I do not need them.
    Price: $100.00 (Picked Up) $108.95 (Shipped)
    D16Z6 Head
    This is another item that has just been sitting around and the work intended for it never surfaced. Because it has been sitting around with no valve cover you can see it has become very dirty and is going to need to be cleaned up. It would be perfect for someone that is in need of a head for a build that is going to get machined anyway.
    Price: $30.00 (Picked Up) - Prefer not to ship
    D16Z6 Head with Valve Cover
    Yet again another item that intentions never surfaced for. It is not as dirty as the head with out the valve cover but it would probably be a good idea to have it sent off to the shop before use.
    Price: $45.00 (Picked Up) - Prefer not to ship
    Spoon Sport Front and Rear Lower Tie Bars (EG)
    This is a front and rear lower tie bar by Spoon Sports. The brackets for the front bar are missing but I have talked with Spoon dealers here in the US and they can be ordered, I just never did it as the bars added no real benefit to my set up. The rear Bar is complete minus one nut that can be purchased at any hardware or auto parts store for a few cents. The bars are in perfect condition minus the missing brackets. I have had them in storage for a while now and put the protective plastic back on the bars. Both come in the original plastic and have the original instructions as well.
    Price: $215.00 (Picked Up) - Willing to ship
    86-89 Accord Brake Booster
    I have this laying around from one of the couple of older Accords I had for a short period and definitely have no need for it. It worked fine when I removed it from the car.
    Price: $5.00 (Picked Up) - Willing to ship
    92-95 Civic AC/Heater Core Evaporator Box
    Another item that was removed from my 95 EX Coupe when it was being gutted. The box is cracked however you should be able to transfer the evaporator to another box or use it like it is. It worked fine in my car as the box sits.
    Price: $12.00 (Picked Up) - Willing to ship
    99-00 Civic Si Center Console
    This is a center console with the cup holders and center armrest out of a 99-00 Civic Si. I had these retro-fitted into my '95 coupe and when the car was gutted this came out along with everything else. If someone wants the center piece I cut out to make this fit into a fifth generation Civic let me know and I will through it in. The EM1 console has not been modified in any way.
    Price: $35.00 (Picked Up) - Willing to ship
    D16Z6 Distributor
    This was taken off of one of my engines I have laying around the last time I dropped on into my car . It has no cap, and how you see it is how it will come. It worked when I removed it from the engine I just replaced it for one that was newer.
    Price: $25.00 (Picked Up) $33.95 (Shipped)
    92-95 Civic Cruise Control Switches
    These were removed from my car once again when it was gutted. The switches worked perfectly just before being removed.
    Price: $5.00 (Picked Up) $10.00 (Shipped)
    92-95 Civic Defrost Switch
    92-95 Civic Sunroof Switch
    13" Honda Accord Hubcaps
    These came off of an '86 Honda Accord. The have minor scratches but are in great shape for their age.
    http://photos.tmitbyh.com/forsale/for_sale_089.jpg[img]
    [B]Price:[/B] $20.00 (Picked Up) - Willing to ship
    [B]Almost Complete 92-95 Civic EX Coupe Interior (Black)[/B]
    I am missing photos of most of the items as they were deleted after I put the items in storage. I plan to get them out this weekend and store them in my garage. Right now I do not want to part any of the interior out. Included is everything minus the sunroof cover, the center console (from the ashtray section to the e-brake section), the dashboard, and the steering wheel. Everything else is there. The door panels are still in my car but will be removed for the sale. Everything is in really great shape. The only flaw in the entire interior is a small burn mark on the back seat bottom cushion where a cherry flew into my window from a passing car and landed in the back seat. I have pictures of the interior when it was in the car if you would like to see that for right now. Below are a few of the piece I still have here in the garage. I am also asking with this a passenger seat. I do not care about the color or condition of it just as long as it will bolt up to my car with out any modification or issue.
    [IMG]http://photos.tmitbyh.com/forsale/for_sale_076.jpg
    Price: $300.00 (Picked up) - Will not ship
  3. eicivic
    eicivic Senior Member
    Would you please ship...?
    I want the Z6 block that is assembled if its in good shape and just needs to be cleaned, decked etc...and ready for a rebuild. Also wanting the vtec head to match.
    I will pay shipping but all that i ask is that you make sure its wrapped twice with cardboard and tapped well. I live in missouri and it would be going to a business address.
    LMK.
    Thanks!
  4. eighty-fo_hatch
    eighty-fo_hatch New Member
    bump, nice presentation... :eek:
  5. tmitbyh
    tmitbyh Member
    Street Imports Ronin Style Driver Seat (ITR Replica) sold to 93redfox on CSCC.
  6. mylasthatch
    mylasthatch New Member
    do you have the intake manifold?
  7. tmitbyh
    tmitbyh Member
    For what? :confused:
  8. mylasthatch
    oh sorry... for the z6, need to find something to replace my hf mani a z6 or b7 , just something bigger
  9. SinisterCivicSI
    SinisterCivicSI New Member
    I need the knock sensor from the block and i need a D6y8 intake mani complete if you have one?
  10. tmitbyh
    tmitbyh Member
    I do not have any spare intake manifolds.
    I will take a look around and see if I have a knock sensor laying around. If not I might check the bare block for one. Again I do not have any intake manifolds laying around.
    Those waiting on shipping quotes, I apologize for the delay. I ask for your patience and to bear with me on it. I will have something to you by Friday or Saturday depending on my schedule.
  11. denbow981
    denbow981 New Member
    Would you please ship. one of the block..? I want the Z6 block that is assembled I will pay shipping let me know if you can asap thanx.....
  12. eicivic
    I was the first one to reply to this thread and i even pm'd him at the same time. And he told me that it was in the process of being sold. I wanted the Z6 assembled block and the head with the valvecover. But oh well i guess.
  13. tmitbyh
    tmitbyh Member
    CTR Replica Leather Shift Boot sold to asianboi313 on Carolina Hondas.
    92-95 Civic Digital Dash Clock sold to Eyal 951 on D-Series.
    Most items not sold by Friday evening will be listed on eBay.
  14. tmitbyh
    tmitbyh Member
    Now is the time to make offers.
  15. nbdzhro
    nbdzhro Junior Member
    I'm interested in the 99-01 Center Console. How much shipped to 27104? Thanks
  16. tmitbyh
    tmitbyh Member
    There is "suppose" to be a guy here locally coming to pick it up tonight. That was what I was told earlier in the week anyway.
    Anything not sold, having a deposit on it, or truly spoken for will be put on eBay tonight.
  17. LSVtecSdn
    LSVtecSdn New Member
  18. tmitbyh
    tmitbyh Member
    Mid-day stretch, here we go...
  19. nbdzhro
    Well if it's not sold I can send you the paypal money quickly.
