SC Fs: D16a1 longblock 400 obo
John.CRX
Slow
For sale is a D16A1 longlblock more or less.
Some new gaskets, head has been machined and valve stem seals replaced with new. I have 3 pistons with brand new rings, one without because I boinked it up putting it in the block. No bearings or thrust washers. Engine was running but burning oil when pulled from the car. I have the head, crank, pistons, intake manifold, cams, pistons, water pump, Distributor and cam angle sensor, along with a harness to use to plug into a 3g Si harness, ECU, new timing belt, new timing belt tensioner (no spring, I can get one though), alternator, alternator belt (I think, not sure), A/C pump (unsure of condition) and bracket, crank pulley and gear, flywheel (somewhere, again not sure, needs badly resurfaced, anyway). No valve cover, but I can get one if you really need one. Parts still have some assembly lube on them but they are all bagged up and ready for you to pick up! I also have a owner's manual for this model Integra.
Will trade for SOHC parts or a full A/C setup for D16A6. Pickup or meet halfway, I will not ship these items unless small. Yes I can work out a deal in individual parts.
appreciate it, i just dont feel like spendning 150 buck for one, but im gettin desparate I need this car running.
