FS: dc2 type r swap teg (built)
540guy
Well im selling my 1994 integra ls with a 1997 jdm type r swap. I just had the motor rebuilt in December 07(pistons rods crank full cleaning of head) and since there is under 1000 miles on motor and turbo setup. The bad: needs body work. Golf ball rust hole in drivers side 1/4 panel. Wing was removed and is now covered in bondo and will need paint. Also just replaced drivers side fender which will also need paint.
car made around 415 whp on 14 psi.
looking to get 9k OBO.
located in western new york.
looking to get
Motor/Tranny:
-1997 JDM Integra Type R
-Hone and Bore .020"
-CP 81 1/2mm. Pistons
-Eagle Connecting Rods
-ARP Headstuds
-Golden Eagle Block gaurd
-New in 2005:
(OEM valve seals, Honda gasket set, Water pump, Oil pump)
-RC 750cc Injectors
-Edelbrock Victor X Intake manifold
-Edelbrock Fuel Rail
-Holley fuel pressure regulator
-B&M Fuel Pressure gauge
-Hasport Extreame Motor Mounts
-Walbro 255 High pressure fuel pump
-ACT Springless 6puck clutch heavy duty pressure plate
-New C/V Shafts
Turbo/Cooling:
-Percision sc t-61 turbo
-Custom log manifold
-Drag3 Air intake
-HKS SSQ Blow off valve
-Tial 38mm Wastegate
-Drag 3 spearco bar and plate intercooler (core is 22x7x2.5 inches. inlet is 2.25 and outlet is 2.5 inches. total width of intercooler with cast endtanks is 27 inches.)
-KTeller 3in. stainless steel exhaust
-3in. magnaflow muffler
-Custom stainless turbo piping by Hybrid
Suspension/Brakes:
-Koni Yellow shocks
-Gold Line 2 1/2in. springs
-Energy Suspension front bushing set
-APC Rear aluminum strut bar
-Powerslot Rotors front/rear
-New tie rod ends
-New front wheel bearings
Interior:
-Autometer 2 gauge bezel
-JDM Cluster
-Autometer sport comp boost gauge
-Autometer Air/Fuel
-GReddy Profec B Spec 2 Boost controller
-GSR clothes
-new black carpet
-Skunk2 Short shifter
-Skunk2 Shift knob
-Type R shift boot
-Black dash and honda steering wheel
Exterior:
-98 Integra Tail lights
-Rota auto x wheels
-Carbon creations carbon fiber hood
http://www.flickr.com/photos/2...10977/http://www.flickr.com/photos/2...22228/
http://www.flickr.com/photos/2...86263/
http://www.flickr.com/photos/2...71856/
http://www.flickr.com/photos/2...03783/
more pics upon request. need this gone. open to trades!
