FS: LS/Vtec Setup
Discussion in 'Parts: For Sale/Trade/Wanted' started by unix4linux, Jun 23, 2005.
  1. unix4linux
    unix4linux Senior Member
    Hello All,
    I am selling a B18B1 Block with a GSR Head. Both have been worked on and have not been used/installed on anything yet. I don't want it anymore cause I am moving and could use some money for my new place. Everything is in perfect condition. I am asking $1000 for the head and I spent $1200...for the block I am asking $700...here are the details and the links below are the pics:
    B18B1 Block:
    Hot Tanked
    Decked 5/10000ths
    LS Crankshaft
    Main Caps
    Every Single Bolt and sensor for the block is included
    Missing crankshaft pulley
    LS Rods
    .50 overbore
    Integra Type R Pistons w/rings
    Rods need to be machined to fit pistons
    Alternator and bracket
    All Gears for Timing belt including tension gear
    Oil and Water Pump also included
    A/C Bracket and Compressor
    Power Steering Bracket and Pump
    Oil Pan
    Oil Pickup
    GSR HEAD:
    Skunk2 Valves
    2 Ferrea Valves because its just the way I got the head but it will not affect performance at all.
    Skunk2 Retainers
    Bronnze lower and upper keepers
    New Honda Seals
    Skunk2 Springs
    3 Angle valve job
    Milled head
    All Bolts except for head studs are included and valve cover
    GSR cams
    Stock CamGears
    Vtec Solenoid
    Sandblasted
    I am willing to sell one item or both together but will not Part Out!!!
    If you have any questions email me at unix4linux@tampabay.rr.com
  2. formby
    formby learning in progress
    bad links....bump
  3. unix4linux
    Sorry about the links guys...don't know what happened there...if you are really interested email me for pics
    Email = unix4linux@tampabay.rr.com
  4. unix4linux
  5. unix4linux
