Fuel Additives
Discussion in 'General Tech and Maintenance' started by Xaero3953, Oct 26, 2005.
  1. Xaero3953
    Xaero3953 Senior Member
    Ft. Worth, TX
    I took a cab today to work and the fkn guy who was driving, (45 min late) told me that he had been adding acetone into his fuel and was getting really good mpg increases. He said some people claim 35% mpg increase. Something about helping the gasoline evaporate quicker or something.
    Is there any validitity...er...truth to this, or was he feeding me total Bullsh*t?
    Thanks [​IMG]
  2. Nuke209
    Nuke209 Member
    acetone helps, if i can remember the link, i'd post it, but u can look it up on google and find some articles about it
    I've tried it a few times, got like 20 more miles outta my camry?
    so yea...works different for others
  3. Nopspawn
    Nopspawn Senior Member
    So Cal
  4. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    This has been discussed at some length in my local Subaru forum. There were a couple of other links posted as well. You have to be pretty exact about how much you add, but you'll see nowhere near a 35% increase in fuel economy.
    I've been using it for about 5 tanks of gas now. The first three, the gains were zero to minimal. The 4th tank, I got some HORRID gas mileage. I don't know what caused it - bad gas, too much acetone, etc. So I told myself, I'll try it for two more tanks, and if I don't see an improvement, I'll just quit it.
    I WILL say, however - I feel very strongly that adding acetone helped me pass emissions. I'm running a custom tune on my WRX making a decent amount of power, with only one high-flow cat (WRX's have three from the factory). I expected my emissions readings to be close to the limit....nope! I passed with flying colors. Acetone supposedly helps the fuel burn cleaner and more efficiently, and THAT part I believe.
  5. Pewble
    Pewble Senior Member
    I would not do that.. your gas tank could melt or something...
  6. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    lol. I don't think so. I think acetone has the same ingredients as octane booster, so theoretically, you could use it as such if you knew what you were doing.
  7. DwnShftPrincess
    DwnShftPrincess Senior Member
    Orangeburg, SC
    i'll keep paying $2.25 a gallon for gas
  8. LudeBoy
    LudeBoy Slave to the EF
    STL
    Higher octane doesn't exactly mean better. If you adjust your timing to take advantage of the higher octane then yes you will see more power and effeciency. If you don't adjust your timing to take advantage of it you probably will lose a little power/effeciency.
  9. dohcvtec_accord
    The left lane
    It won't eat your gas tank or your lines. You're adding an ounce or two of acetone per 10 or 15 gallons of gas. Talk about diluted.
    Additionally, the guy in the article I quoted above did an experiment where he took some fuel line and let it sit around in a bucket of acetone for a ridiculously long amount of time. No corrosion to speak of.
