Fuel And Cooling, B16 Crx
Discussion in 'HYBRID -> EG-EK / DC' started by heterosapian, Feb 19, 2003.
  1. heterosapian
    heterosapian Senior Member
    exit 152, I-95
    Should I be worried about replacing/supplementing the fuel pump and radiator on my 89hf when the b goes in? I'm assuming i'll need both because i'm quite the lead foot now (i know, i know, its an hf, maybe thats why i stomp it constantly ;) ) and that might cause problems with the mighty b and the puny pump and radiator in there now.
    if yes, then any part suggestions would really help. TIA
  2. tegar91
    tegar91 Junior Member
    just purchased a 90 HF and a some what built B16a (ITR manifold, CTR pistions, STR fuel rail, GSR cams, AEm cam gears, etc. ) what do i need to swap SMOOTHLY? please help
  3. cbrnascar0329
    cbrnascar0329 Banned
    :gives: start your own thread and stop ripping on this one
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    i have not heard of people having problems with the fuel pump or radiators on swaped b16 in CRXs... I have swapped a few b16s in 90-91 civic hatchbacks and they are all still running stock radiators and fuel pumps. All those motors are running ctr pistons and cams, with skunk2 valve train.
  5. heterosapian
    exit 152, I-95
    nice one, thanks. I think i'm gunna go ahead and add a zex inline since i'll be running a jrsc later anyway. I'm fabbing up a water injection system (complements of those crazy dsm guys over at vfaq.com) so hopefully under boost the stock radiator will sufice.
    thanks again
    peace
  6. pissedoffsol
    if you are going to a jackson, consider a 255lb/h intank, not inline.
