Fuel Economy
Discussion in 'Integra' started by TysonB11, Jun 28, 2008.
  1. TysonB11
    TysonB11 New Member
    Which part replacements and or mods can improve fuel economy?
  2. 99sidude
    Ohio
    Keeping your car tuned up is the easiest thing you can do. Change your oil every 3k, make sure you have a clean air and fuel filter, replace the plugs if they are fouled up. Make sure the valves are adjusted to spec. Keep your tires inflated properly and the wheels aligned.
  3. 99sidude
    Ohio
    If you want mileage find a d15z1 swap and throw it in your teg
  4. TysonB11
    TysonB11 New Member
    Yea, but how much $ would that be?
  5. 99sidude
    Ohio
    Idk prolly 500 bucks for everything. Really though, your integra gets 30+ mpg as it is. If you want insane mileage trade it for a stock crx hx.
  6. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Lighten your car and dont carry passengers works too.
  7. 99sidude
    Ohio
    Carpooling is by far the best way to save gas $. That or ride a bicycle to work.
  8. awptickes
    MD
    Take the number 1 and 3 pistons out. Then disconnect the injectors, block off the plenums on the intake, block off the exhaust ports, and finally remove the spark plugs. You should get 2/3 better fuel economy with this mod.
  9. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    :huh:
  10. awptickes
    MD
    Well, maybe 2/3 is an over-estimate. But he'll certainly use less gas.
  11. YBLEGAL
    NW Indiana
    has this been done? link? sounds rediculous. never heard this. it must be rough...
  12. awptickes
    MD
    I'm sure it could be done.
    I seem to recall an old army field manual with directions for running an old jeep engine off two cylinders, and using the other two for compressing air for tools. I'll try to find that.
  13. 99sidude
    Ohio
    That would totally fuck the balance of the engine
  14. 99sidude
    Ohio
    yet be a sweet project if I had a spare civic and d15 laying around
  15. Justin66
  16. hope801
    hope801 Active Member
    i got an original d15 from a standard 91 civic, in my crx. i get about 48 highway mpg
  17. Rex Plumlee
    Rex Plumlee New Member
    Tulsa, OK
    best MPG for my crx
    I just bought a basket case 86 CRX which I'm starting an engine search for. I'm after max MPG. The original engine was an EW1 with a 5 speed. I've seen the HF models used a B13 but I've not located one of those here locally in Tulsa. My car was originally carburated but I've got a megasquirt and am thinking about going injected. Any engine suggestions for most MPG, easiest availablility, least conversion pain/expense?
  18. BrutalB83
    Rochester Hills, MI
    My first suggestion would be to start your own thread in the appropriate forum...
  19. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    :doh:
  20. hondarin
    Texas; where else?
    lower you coefficient of drag : lower your car, put on lightweight wheels with covers, take off your spoiler if you have one, put on some underbody diffusers/panels, tape up the seams in the front of your car around your headlights and hood, remove your antenna, remove one windshield wiper, remove passenger side mirror, place covers over your rear wheel-wells that follow the lines of the body, put some of those mini-vortex generators (like the evo has) on your rear deck, etc.
    remove all the interior except the drivers seat/steering wheel/shifter. put on narrower tires with harder rubber compound and a shorter sidewall. remove the power steering pump and air conditioner. free up the intake and exhaust and keep your foot out of the throttle.
