Fuel injection b16a turbo
Lee7pcNOOb
If you have a stock b16, only wanting to push 2-3 psi. do you have to get bigger fuel injectors?
fuel pump?
Oh yea... you will need a missing link so the MAP sensor doesn't read boost and throw the ecu into any unwanted modes.
i think the max i would even try is 4psi, just wondering cause im ganna build my own kit and not having to buy fuel injector for such a small boost would save me a little cash
you WILL need larger injectors.
stock 240cc injectors will support about 200 WHP on a lean tune.
but 2psi.... is really an entire waste of your time and money. if you want a 15 hp gain, throw in some cams. a lot easier.
agree with B , there is other ways to get a little more power. if you are installing turbo that means that you want at least 180whp or more, actually that's the question , how much whp you want at the end of the proyect?
