I have a h22a that's been sitting for a while and I'm wondering about the fuel injectors. I heard that they are quite expensive to replace, but I guess I should get them checked before I do the swap right??? Are the injectors pretty good on this motor or you think I will have to replace them? Thanks
You shoulda done more research before starting this. Just get some injector cleaner and run it through your system after you get the swap up and running. You'll know if you have a bad injector, and can get it cleaned/replaced if needed.
You mean research on the engine before I bought it? I will do that when the engine is in thanks for the help.
never heard of this problem before. and it wont be expensive if you stay away from honda to replace them.
