93gsintegra
Member
hello... i have a 1994 ls with a t3/t4 kit on it. i have a fmu to spike the fuel and i have noticed it running real rough at idle so i put on a b&m fuel gauge and i am carring over 120psi of fuel at idle?? do you think my regulator went bad?? it is a sock reg so i could keep my base fuel stock... but i did by the b&m command flow adjustable regulator but if this stock regulator is bad i dont want to go through the hassel of modifing it so the command flow will fit it... also have a 255lph pump
