Funky Temp Gauge
Discussion in 'Civic and CRX - EF' started by mxgx12, Apr 29, 2011.
  1. mxgx12
    mxgx12 New Member
    lancaster, CA
    I got a 91 crx w/ DOHC ZC. Recently, after the car has been running at full temp for a few minutes, the temperature gauge needle starts to go crazy. It'll bob up and down sparatically, and also dip in direct relation to the gas pedal. I can stop at a red light and the needle will rise back to regular level, but once I hit the gas and start accelerating it'll drop down. I believe this is some kind of sensor problem or something. I know it's not the actual engine temp, my heater works, so I know the thermostat is working. The engine is operating normally too. So IDK, It's freaking weird . anyone seen anything like this or have an idea what it could be? Any help is much appreciated
  2. mxgx12
    mxgx12 New Member
    lancaster, CA
    Somebody? Anybody?
  3. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    its thermostat. most likely. same thing happend to my car once. was stying open. heater will work but if it gets to cold if will blow hot air but not that hot.. change it. c what that does.
  4. josh_crewdson@y
    josh_crewdson@y New Member
    nova
  5. mxgx12
    mxgx12 New Member
    lancaster, CA
    Ive replaced it. I get hot air. Heater keeps me warm on cold mornings driving to work. So IM confident its not the thermostat. Also, the temp gauge has recently stopped working all together, so Im starting to lean towards gauge cluster. Can only one gauge on the cluster fail? while the others operate normally?
  6. dc4dude
    dc4dude Member
    chicago, il
    Swap out the coolant temp sensor before you go replacing entire clusters.. Also check your connections at the sensors...
  7. m90polk
    m90polk Member
    ri
    Check signal coming from coolant temp sensor with ohm meter to make sure its good. Also check your harness might have an intermittent connection an when you hit the gas the wire is gettting moved from the engine motion on accelerating.
