jfields0622
Just got done with my dohc zc swap. And I used the DX transmission, because the ZC tranny wouldn't bolt in. I used the ZC starter.
The gears shift fine when the car is off. But when I turn the car on the gears just grind, I can't get it to go into any of the gears 1-5 and reverse.
Clutch Cable?
Starter?
Tranny Problem (the tranny worked fine on my dx, no issues, and everything looked good when i switched it).
Clutch Cable?
Starter?
