Getting ECU Trouble Code #9
Discussion in 'ECU's, Electronics, and Tuning' started by mdixonjam, May 27, 2005.
  1. mdixonjam
    mdixonjam Member
    Kingston, Jamaica & Miami, FL
    How do I troubleshoot an error code #9 ??
    I have 95 LS/VTEC with an OBD1 ECU, distributor, etc. using a Conversion Harness adapter.
    I am using a P28 chipped ECU which is looking for the Knock Sensor signal. This initially triggered a CEL code #23 which corresponds to Knock Sensor, but the car idled very erratically.
    In checking it out a friend found out that the plugs were messed up - so we replaced them and the engine sounded much better and revved out pretty nicely.
    But now the CEL #9.
    What could cause this ??
    Thanks for any help.
  2. pissedoffsol
    p28 ecu's don't have knock sensor circuitry. there's no way it can throw a code for it.
    as for code 9, check your timing betwen your cam gears and crank pulley.
