streetrays
Member
please visit http://www.streetrays.com for more!
we now carry golden eagle products in-stock, including:
golden eagle cam gears
golden eagle fuel rails
golden eagle block guards
golden eagle head studs
golden eagle vacuum manifolds + fitting kit
golden eagle VTEC conversion kit
Synapse Synchronic Fuel Pressure Regulator
Acura/Honda - D16, B16, B17, B18, B20, F20, F22, F23, H22, H23
Nissan - SR20, KA24, VG30
Toyota - 4AG, 4AGZE, 5SFE, 3SG, 3SGTE
Synapse Synchronic Fuel Pressure Regulator is a bolt-on all in one solution for all motor, nitrous or forced induction engines. Allows for infinitely adjustable boost dependent ratio from 1:1 to 12:1 and adjustable static fuel pressure from 16 to 80 psi. Its solid piston design with no diaphragm will prevent from rupture or failure. Maintains full fuel pressure when vehicle is powered off, for immediate ignition at next cycle. Potential application to maintain no-return conditions in return less fuel system while compensating for the fuel delivery required for boost. Direct bolt-on installation, requiring no additional plumbing or hoses that introduce leaks and additional points of failure.
Forum deal $204 shipped
-Always in stock-
-Always in stock-
