got LS???
hybrid_b18
crew chief
ive read through pissedoffsols LSmonster build and was not to impressed with the outcome of that motor. 146 from a stock 142?? i am going to follow some of that forum though. im going to the b16 pistons, keeping stock LS rods, but what can i do to the top end that will yield a 600 budget but get more than 4 horse?
basicly i wanna here what people are doing out there to help the LS community whoop on vtec.
tell what type of HP youre gettin and the set ups your using. thanks people.
bills setup also still needed a little more work to see its true potential
1st thing he needed was an ECU that would allow him to rev to 8500+... he was loosing out on 2k RPM so he wasnt even comming close to the potential there
next better breathing... he had a cheap short ram intake going into the stock shittly LS intake manifold.... a skunk2 would have helped greatly... then he was still running the stock shitty LS exhaust manifold... a nice JDM ITR 4-1 would have helped a LOT
so for another $600-$800... he would have easily seen a minimum of 170+whp
Originally posted by B16@Feb 24 2004, 07:27 PM
i think the 142 stock is flywheel HP and the 146 is wheel HP
:thumbsup: More WHEEL hp then a lot of stock B16A's.
okay okay. skunk2 intake? why not just port polish the LS? still too shittay? i was trying to debate whether or not to use a 4-2-1 or 4-1 exhaust. i hear good about both. but what for all motor.? and i have a custom CAI, is that not good enough, should i really spend 170 bucs on a AEM??
yO esol, what RPM can i push my stock valves and cams to? cause i wsa gonna order an new ecu next week.
i wouldn't rev the stock valvesprings/retainers over the stock redline... it's there for a reason. and even if you do rev it out more, you won't see much if any more power if you're still on stock ls cams.
Definitely don't rev over 7500 with a stock LS. My friend had a b18a. Keyword HAD B) . Wait until you upgrade the valve train.
the skunk is a copy of the ITR manifold it has nice short fat runners ... you could never get an LS manifold to flow better than it
get a JDM ITR 4-1 header... its really the best design for hondas untill you start fucking with the uber expensive 4-2-1s that have retardedly long runners before the Ys (SMSP, Hytech, etc $1000+)
a custom intake is just as good as most of the expensive ones (depending on the design and filter used... get a K&N filter for it if you dont already have one)
like everyone else said i wouldnt go above the stock redline
your cams dont make power up there and your valvetrain cant handle it .... engine go b00m!
the motor could probaly go up a couple rpms but i bet they have it set perfectly so if u hit the rev limiter hard and it goes over it wont hurt it.
regardless
so why bother
sounds good sounds good. yea i was gonna go franky-stien but sounds like more work than i would like to do at the present time. so i wanna run my LS hard for now and then do the vtec set up.
yO eSOL. the ITR intake doesnt have that dual stage shit like the GSR right? cause a buddy of mine told me i could use one after taking off the butterfly and stuff.
thanks everyone else. wont push that valve train too hard.
you dont use the actual ITR one ... it wont fit on anything but the ITR or B16 heads without modification
get the skunk2
and no it doesnt have secondaries
