gram light's 57c offset
scottp11
The Seniorest Member....
I did a search about wheel offsets and even read up on the "TireRack.com" tech for offsets. I understand what offset is, but still not sure which offset to go with when I order my new wheels. Currently I have 99-00 Si wheels with 195/50/R15 tires on them, and have no rubbing. I want to use my same tires on the new rims. Does anyone know the offset on the Si wheels and/or what is a good offset for the Gram lights 57c wheels on a 93 civic HB lowered 2 inches? Thanks for all your help!
The gram lights come in offsets +28, +38, and +43 for the 15x6.5 and 15x7 wheels.
The stock offset on 15x6 Integra GS-R wheels is +45mm. It should be the same for your 99-00 Si wheels. Go with the +43mm offset on the Gram Lights and you'll be fine with 195/50 tires.
