my buddy is hooking my up with everything from a 2000 gsr for the brake swap.
i am getting all the front and rear brake parts, lines, master cyninder and brake booster, the lca's and rear sway bar as well for 400 is that a good deal and what else is needed
For the MC, you need the integra Booster as wel (opps, it already says your getting it)l. Also, if your car has does not have abs (I am gussing you don't since you dont even have rear discs lol) then your going to have to refare the rear MC line, however, since you said your getting the lines, that shouldn't be an issue. You also need new Ebrake cables.
Are you getting the rear trailing arms with the rears? You don't NEED them, but it makes the swap so much easier.
