GSR del sol
89guts
my battery light came on the other day so i thought it was my battery going weak and had it tested at autozone, it was bad so i replaced it with a new one and thought my problem was solved but it started to come on again and my idle would bounce up and down at stop lights... i had my alternator tested also that was not the problem and my connections are all good too, has anyone had similar problems?
I'd check the Map sensor or IVAC sensor mite need cleaning... also vacum lines :p normaly a commen problem
