gsr ecu or chipped obd0
Discussion in 'HYBRID -> EG-EK / DC' started by electric-boost, Dec 21, 2002.
  1. electric-boost
    electric-boost Member
    cincinnati
    ok should i keep my obd0 and get it chipped or get a gsr ecu for my b18c swap in my 2genteg. a dude said if i gave him my gsr ecu then he would chip the obd0 and give me 50 bucks is that worth it
  2. E_SolSi
    i dont think your PR4 can be chipped to work with a VTEC engine and im also pretty sure there is no way to make it work with the secondaries... it doesnt support a knock sensor... im pretty sure there is no way that ECU will run that engine correctly.... sounds like your being scamed
  3. pissedoffsol
    try to pick up a pr3/pw0 ecu
  4. possessed imports
    possessed imports Banned
    yes and no
    you can only convert 92-95 obd-1 SOHC VTEC & NON-VTEC ecu's and some 92-95 LS ecu's for DOHC/SOHC VTEC use. Any ecu's pre-OBD1 cannot convert to VTEC.
    for more info go to www.jdmhondaparts.com/frameset-ecu2.htm ;) -_-
  5. possessed imports
    ps dont do that switch with the ecu's :werd:
