gsr flywheel on ls crank
typesiracing
i just got my gsr ACT clutch but the problem is....i think i have an ls flywheel because the pressure plate doesn't line up with the flywheel correctly....does anyone know what flywheel i can use on an ls crank to fit a 94+ gsr ACT clutch
anybody know? do you understand the question......what flywheels will work on a LS crank that will supports a GSR ACT clutch?
that should work, i'm runnin a type r flywheel on mine. keep turnin the flywheel until you see the holes line up.
