gsr head on b16?
Discussion in 'Engine Building' started by 600ryda, Feb 26, 2010.
  1. 600ryda
    600ryda New Member
    ive been lookin to find a b16 head and am currently waiting on one supposedly. but a buddy of mine has a gsr head right now that is fully machined and ready to go. if i put a gsr head on my b16 block wont this lower my compression and by how much are we talkin if so? what are the differences of flow between the heads i mean obviously the pr3 head is better if honda uses them for the type r. and also what do u think of a head that was cracked but now completely fixed?
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    GSR heads have smaller combustion chambers than B16 heads. A GSR head will raise your compression, not lower it. It won't raise it much, IIRC, it'll raise it ~ .2
    The B16/PR3 head outflows the GSR head in the upper RPM range and it's not that significant either. The GSR/P72 head outflows the B16/PR3 head in the mid range.
    Both heads will flow about the damn same when ported so either one will accomplish what you want/need. I for one wouldn't trust a cracked head that was 'fixed' unless I was absolutely confident in the machine shop who did the work.
  3. 600ryda
    600ryda New Member
    yeah thats what ive been hearing and understanding too i just wanted to double check on the information that ive been given. thanx dude
  4. B16RacerN2NR
    Moving back West...
    No problem. Good luck...
  5. Magana559
    Magana559 The Warden
    fresno Ca
    GSR and B16 heads flow the same, only a 2cfm diff.
    I would say go for the GSR head.
  6. devilbob2002
    devilbob2002 New Member
    will the gsr head fit on my b16 bottom? or wil i need a oversized gasket?
  7. Briansol
    they fit the exact same on the block.
  8. devilbob2002
    so my pistins wont hit my head?
  9. Briansol
    if you're using stock pistons/rods/valuvetrain/cams, there's nothing to worry about
  10. newb
    newb phresh VIP
    Backwoods Northwest
    Damn, I came in here expecting a flame fest.
    At least the question got answered quickly, I guess.
  11. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    untill port work is done
  12. newb
    newb phresh VIP
    Backwoods Northwest
    What makes you think that?
  13. phunky.buddha
    Dallas / Fort Worth, TX
    You can't compare a ported head to a stock one- once ported, it's a tossup again.
  14. Magana559
    fresno Ca
    If you port a b16 and a gsr head they will flow just about the same because no 2 heads flow alike.
    I would take a GSR head over a B16 head any day.
  15. hatchbuild10
    hatchbuild10 New Member
    Cali
    so your saying that a B18C1 head will fit a B16A2 with no interference? I am curious to know wha tkind of gains there is with all stock head and block with skunk2 intake manifold and dc headers. will I be better off just swapping cams?
  16. newb
    newb phresh VIP
    Backwoods Northwest
    FUCK!
    Someone, GET HIM!
  17. hatchbuild10
    Cali
    Thanks that did nothing but make you look like you loosing it now everyone is lol@you not with you!! Appreciate the help thank you.
  18. newb
    newb phresh VIP
    Backwoods Northwest
    Thats ok, at least I know how to use Google.
