What year is the motor? If it is 96+ than no, you need to use a 96+ GSR harness. Or swap your injectors onto it, and get an OBD I distributor, then wire up the IAB. I don't know who told you the Civics AC mount would work, but they lied. You need to use one from a CRV, or the P54 one from the DelSol to keep AC, if you don't keep it, any B series one will work. As far as the bracket, why don't you get the GSR throttle cable? Or make a bracket.
