gsr swap need help
90efgsr
i have a 90 hatch that i did a b18c1 swap in and the speedo aint working can anyone help me out
Im not sure which one that is.. did you do the cable to hydro conversion.. or is it still a cable tranny and is it the ls, gsr, or b16 cable???
So you did the cable to hydro conversion... if you did then it has a electronic speed sensor, and you will need to find a b-series cable speed sensor and swap it out... Look down below the throttle body and see if there is a plug sticking up from the speed sensor on the tranny...
Vehicle Speed Sensor is on the transmission....find it and see if its a wiring issue or what.
What did you do for a engine harness???
If the transmission is cable....its ain't a 98 trans...for sure. My guess is its a older B16 Cable Transmission.
