gsr swap questions..?
rrz69
i am putting a gsr in my 94 honda del sol. i have a obd2 gsr motor which has a obd1 distributor with a p72 computer which i was told was a obd 1 computer.. besides a little wiring problems such as injectors and certian other things because the plugs wont work with each other does any one know if i will run in to any other problems.?
You shouldnt have to change the wiring harness all you need to do is put your stock obd1 injectors in place of the obd2. Unless you want the ease of the obd2 clips. My suggestion would be to get a complete engine harness from vtec car with the same diagnostics as your. Life will be easier for u then.
