i want to a least throw 10 psi boost without hurting my engine my how head has been rebuilt with perofrmance cams and gears and has pot and polished. do i go with the je pistons and rods for the rebuilt bottom block for the turbo i'm using probably a drag turbo kit
get some low comp pistons (9.0:1) and some forged rods.... and put your stock cams back in... then you'll be in some good shape
LAST WARNING ROACH you are NOT doing this again. POST YOUR QUESTION ONCE. you do not need 2312312312 threads for the same fucking question. http://www.hondaswap.com/forums/index.php?...t=ST&f=7&t=5022 I WILL re ban you if you keep this shit up. locked. use your other thread for the same question.
